I have a little oil showing on one of the valve cover bolts. What type of gasket sealer is best to use. I used a permatex high temp. Its only one bolt so I'm assuming I didn't get enough sealer on the gasket. Also should the threads on the valve cover bolts have some permatex sealer on them also.
Thanks Mike
Thanks Mike
