1969 alternator - NCRS Discussion Boards
1969 alternator
  • Klaus Friedrich #33362
    1969 alternator
    Was in Austria last week to visit a "Corvette Festival Of Speed".
    The voltage regulator of the original 61A alternator broke down and a bearing sounds bad.
    What is best place to buy spare parts?
    Thanks in advance
    Klaus Friedrich
    Germany
    • 43221
    Re: 1969 alternator
    Klaus------
    Dr. Rebuild carries all of the internal parts that you need to rebuild your alternator. Otherwise, if you wish to purchase the parts in your country, a GM or Delco dealer there should be able to get these for you.
    I recommend that the following parts ALWAYS be replaced when servicing an alternator internally:
    1) BRUSHES-----GM #88921214; Delco #D-732 OR complete brush holder with installed brushes (the only thing that I use) GM #1984462; Delco #D-766
    2) BEARING, slip ring end---GM #9441879; Delco #MNJ711
    3) BEARING, drive end----GM #12339293; Delco #7503-1
    In your case, since you apparently know that the regulator is bad you should replace it as follows:
    REGULATOR, voltage internal type----GM #1116423; Delco #D-680
    You should also check the diodes, rotor, and stator per the procedures outlined in the Chevrolet Chassis Service or Chassis Overhaul Manual. This is very simply done with a volt/ohm meter (VOM). If necessary, you can replace these components, as required.
      Re: 1969 alternator
      Thank you Joe,
      your hints are a great help.
      Greetings from Germany
      Klaus
