Engine ID - NCRS Discussion Boards
Engine ID
  • George D. 31849
    Engine ID
    I looked at a 66' today and could not ID the engine. Casting number is 381001 and front pad reads 158452563 K10 26OMJ
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Engine ID
    MJ looks like 1967 283 195 hp 2 barrel powerglide camaro
      • 43241
      Re: Engine ID
      George-----
      I can't find any record of a block casting number of 381001. Are you sure the number isn't actually 3970010?
      Also, I suspect that the engine ID code is "K1026CMJ". This would make the block an original Canadian-built small block of 350 cid and used between 1974-76. There are a few other possibilities, too, but this would be the most likely. The block casting date would narrow this down.
      • George D. 31849
        Re: Engine ID
        There were two of us that read the same block number. Is it possibly a 283 ?
          Re: Engine ID
          The VIN derivative says the vehicle it was originally installed in came out of the Shreveport, Louisiana plant in 1975; Shreveport has always been a truck plant.
