Members,
I have a question regarding the choke tube, hot air manifold system on my '65 250HP.
The heat tube goes from the choke housing to the exhaust manifold. OK
The fresh air tube goes from the rubber hose connected to the carburator to the bottom of the exhaust manifold. OK
Question is: Is there a third tube inside the exhaust manifold that makes the connection between the clean air tube and the hot air tube? Or does the clean air tube insert into a long hot air tube that goes all the way through the manifold from the top? To ask the question more directly: Are there two tubes or three?
Thanks for your help.
Gene
Gene
