water pump - NCRS Discussion Boards
water pump
  • Verle R.
    • March 1, 1989
    • 1163
    water pump
    Can someone tell me the application for water pump number 3782608?
    Thank you,
    Verle
    Re: water pump
    That casting was used for MANY years from the mid-60 to early '70 era on low HP SB Corvette engines as well as on Chevy passenger cars. Also, the pump body was cast by both the Saginaw and Tonawanda foundries and only the Saginaw/Flint version of the water pump is correct for Corvette. Look for a 2-digit year code on those pumps that were dated as well as a 'T' embossed in the front surface near the mold ID (GM3, Etc.) emboss to spot a Tonawanda water pump...
    • Verle R.
      • March 1, 1989
      • 1163
      Re: water pump
      Thank you sir, I appreciate the information.
      Verle
