Out of a 1958 270 hp 3 spd, rear end AP 503 (possibly the 3 is a poorly stamped stamped on the outside of the carrier flange. The AP stands for 4:11, three speed which came out of a 1958 270 hp 3 spd. Is this the rear end for that car? The serial # of the car is J58S107275. There are other casting #s on the carrier.
C1 - Rear End Question
Re: C1 - Rear End Question
The "born on" date is May 21, 58 for your car. The AP503 stands for 4.11 positraction for 3 or 4 speed, assembled on May 3. This should be stamped on the passenger flat side of the carrier. On the drivers side there should be a thin P, a cast date code, the casting code. Make sure the cast date code is a '58 cast code and it has the correct thin "P". Assuming that checks out, I'd say it's original to the car. Ted- Top
AP is the correct code for Corvette 4.11 with posi from 1957 through 1961. The 5 03 is assembly date of May 3, with no year designation. Next to the casting number (on the opposite side of the carrier)is a casting date, alphanumeric. (such as D278) That will tell you the date and year that it was cast.- Top
