The Lip under the hood is body color all the way around if I'm reading things correct. The hood was in place when the blackout was applied. Front of hood may not have total coverage. Can you see any overspray of body color on the lower part of the hood where blackout missed or was thin. Also if using shims under the hinge were these in place and should have blackout paint on there edges.
Thanks Mike
Thanks Mike
