Re: ? Engine Casting Number - NCRS Discussion Boards
  • Paul T.
    re engine casting number paul t george typically the ce code indicates a chevrolet replacement engine the ce designation was used on all replacement engines during the s without regard to options good luck
    • 43236
    re engine casting number joe lucia also you better check that casting date again the casting number that you mentioned would have been released no earlier than about
