C2 Hood Blackout and Paint - NCRS Discussion Boards
  • Mike M.
    • September 30, 1999
    • 710
    I'm fixing up a few things they found wrong in judging a couple weeks ago.
    Judging guide refers to the hinge area and says the structure curves toward the center of the hood aproximately 1/4 in. At this point the blackout does not follow the curve of the structure.
    The question is, are they talking about the rear of the hood where the hinge pins are,and they ran masking tape around the outside of the hood to prevent blackout paint from getting on the outer lip. Was the masking tape wide enough to cover the whole outer lip. Or should a portion show some blackout paint.
    Thanks Mike
  • Zachary K.
    • March 1, 1986
    • 162
    Re: C2 Hood Blackout and Paint
    They are talking about the area down by the hinges. If you follow the inner corner (say where the weatherstrip seats) down you will see an area that slightly curves in, the black out there should follow the above line down.
    Just a note the paint line should not be sharp but should be a dusting of the blackout into the color of the car. Also down by the hinges the blackout tapers outward on an angle with the same dusting look.
    I have pictures of an original car and will try to post them if I can figure out how to do so. I've never tried this yet, wish me luck.
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
