66 A.I.R. Pump Mounting bracket - NCRS Discussion Boards
  • Carl Sanger
    I have two and can not determine, from the AIM,(or anything else for that matter), which one is correct for Mr. Sangers 66 350hp
    1; GM #3882861
    2. GM # 3923214
    As always any suggestions would be helpful and appreciated.
    jer
  • Loren L.
    • April 30, 1976
    • 4104
    Oct 1 1967 PBk carries #3882861 for
    66-7 327 and #3923214 for 68 327 - Gr3.655
      • 43236
      Re: 66 A.I.R. Pump Mounting bracket
      Carl-----
      The GM #3882861 is the original and correct bracket for 1966 and 1967 small blocks with AIR. The GM #3923214 was first used for small blocks for the 1968 model year and also replaced the 3882861 for SERVICE. Both the 3882861 and the 3923214 will be equally functional for your application, but the 3882861 is the correct bracket.
      • Jerry Clark
        Re: Oct 1 1967 PBk carries #3882861 for
        Thanks Loren
        notsangercarl
