C2 engine startup - NCRS Discussion Boards
C2 engine startup
  • Joseph K.
    • March 1, 1980
    • 168
    C2 engine startup
    Am getting ready to start my corvette after a long sleep. The car has set with a newly rebuilt motor some 20 years and am wondering what I need to do before attempting to do so. I am not in a hurry so will wait for any replys. the motor is a l79/m20, 65 coupe. Thanks so much for your input.......Joe
  • Al Corelli
    Re: C2 engine startup
    Was the engine started after the rebuild to break in the cam?
    • Joe R.
      • July 31, 1976
      • 4551
      Joe,
      AC has a good question and I would treat the engine just like a fresh start up even if it has been broken in.
      In addition before starting I would do the following:
      1. Drain oil if present and replace with fresh oil
      2. Replace oil filter and fill oil filter with oil
      3. Add Chevrolet EOS (Engine Oil Supplement)
      4. Remove plugs and put about 2 oz. of 30 wt. in each cylinder
      5. Turn engine over by hand about 12 times
      6. Pull Distributor and prime oil pump
      7. Start up now as new rebuild
      Hope this helps,
      JR
      • Joseph K.
        • March 1, 1980
        • 168
        To my knowledge this motor has never been stared since rebuild.....Joe
          • 43234
          Joe------
          The very first thing that I would do is to try to turn the engine over by hand using a socket on the balancer bolt. If it's "frozen" then you can skip all of the other pre-startup steps and proceed directly to engine disassembly. I hope that doesn't happen, but it is a possibility. If the engine does turn over by hand, then follow JR's checklist.
          • Joseph K.
            • March 1, 1980
            • 168
            The motor does not seem to be frozen.....Thank you all for your help..Joe
