C2 67 Storage area cover - NCRS Discussion Boards
  • Stephen L.
    • May 31, 1984
    • 3153
    How is the carpeting secured to the storage area cover fiberboard????
    Glue, staples, sewn, or a combination of the above?
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 67 Storage area cover
    Steve:
    Use the same glue that you used to secure the carpet to the padding. Assume that you used 3M Spray Carpet Adhesive.
    Joe
    • Stephen L.
      • May 31, 1984
      • 3153
      For some reason, my storage backboard has a series of holes in it around the edges where staples or a very tough sewing machine had been. I replaced the original back in 1983 and can't remember how that was attached. I did glue on the replacement back then which now needs replacement again. It has faded to a very dark chocolate brown. See the photo for the hole pattern......
      • Joe C.
        • August 31, 1999
        • 4598
        Steve:
        Here is an excerpt from my 1965 TIM&JG: "Carpet is glued on the top of the cover and should closely match the size of the cover with minimal overlap". I am almost certain that your 1967 TIM&JG should read the same.
        Joe
