BB Oil Pan - NCRS Discussion Boards
BB Oil Pan
  • Richard G.
    • December 1, 2001
    • 107
    BB Oil Pan
    Is this oil pan an original style pan for a 68-69 427, P/N #3958658?
    Rich
    • 43221
    Re: BB Oil Pan
    Rich------
    GM #3958658 would be an original style pan if you had a 69-70 Chevrolet passenger car with big block. However, it's not the original style pan if you have a Corvette.
    • Richard G.
      • December 1, 2001
      • 107
      Re: BB Oil Pan
      Thanks Joe
      • dick foehringer
        Re: BB Oil Pan correct number?
        so what is the correct number? i need one also as mine in pretty dented up? regards dick
          • 43221
          Dick-----
          The currently available SERVICE replacement is GM #14091356. It's very similar, if not identical, to the original pan. For 1970 and older applications you'll need to add the corner reinforcements for correct, original appearance. These are available in reproduction and don't need to be spot welded to the pan-----the bolts will hold them on just fine.
