69 wiper motor ( headlight washers) - NCRS Discussion Boards
  • John S.
    • July 31, 1990
    • 292
    I know 69 had a unique headlight washer system, did any other GM model have headlight washer's? I picked up this unit and it is very close to the 69 corvette. Thanks john
    • 43205
    Re: 69 wiper motor ( headlight washers)
    John------
    Vaguely, I recall that, perhaps, late 60s-early 70s Oldsmobile Toranados and/or Buick Rivieras may have also had the headlight washer system. I have no way to confirm that, though.
    • Chuck G.
      • May 31, 1982
      • 2034
      Seems I remember that the 69 Camaro with the "hidden headlight" option used the same washer. Chuck
      • Reba Whittington
        You are correct, Chuck. The 1969 RS Camaros had the same option.
          The '69 Camaro RS models used it, and it was also available stand-alone as RPO CE1 Headlamp Washers; however, the Camaro used a totally different wiper motor than the Corvette. The headlight washer solenoid assembly for the Camaro was never reproduced, and they are HIGHLY ($$) sought after by Camaro restorers.
          • Scott Butville
            If you're not after 100% correct, put a "T" in one of the windshield washer lines and hide it under the wiper motor.
