Air cleaner base carb extensions (62-340) - NCRS Discussion Boards
  • Rob Edwards
    Does anyone know whether any of the suppliers of repro air cleaner assemblies make an air cleaner base that features the small carb-locating extensions that are discussed on page 47 of the '61-62 TIM&JG? The current repro I have (don't know where the PO sourced it from) lacks the extensions. Thanks!
  • Chris H.
    • April 30, 1990
    • 817
    Re: Air cleaner base carb extensions (62-340)
    I bought a Vette Products part here in Michigan and it did not have the extensions. I believe they made the part themselves but will confirm when I return it. They said that it was not supposed to have extensions. I will take in my original part and the JGM to show them.
    I also called Corvette Central and they have a part supplied by a company called King Products which I could find no info on the web. It also does nat have the extensions.
    I am going to have my base cad plated (or is it zinc?) and then tyr and get someone to pad print it.
    short answer is I do not know of a good part source. Let me know if you find one.
    Chris
