C1 Block pad stamp - NCRS Discussion Boards
C1 Block pad stamp
  • Kevin Riel
    C1 Block pad stamp
    I'm looking at a 519 block for my '59 that has the pad stamped F4I3DG. Did the factory use an upper case "I" to indicate a "one"? I was assuming that this block was assembled on the 13th of April in '59, but I'm wondering about the upper case I used for a one. Is this correct?
    Kevin Riel
  • Mike E.
    • February 28, 1975
    • 5138
    Re: C1 Block pad stamp
    Absolutely correct.
