C2 starter heat shield fastener - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    Looking for information regarding P/N 9420494 fastener (per '65 AIM). It is the bolt that holds the starter heat shield to the starter support bracket.
    I believe that it is a number 10 screw/bolt with 24 tpi. Question is: What is the length and head configuration? Hex head bolt, slotted head screw, phillips, etc?
    Also interested if lock washer is used. AIM does not show one.
    Gene
    • 43221
    Re: C2 starter heat shield fastener
    Gene-----
    The screw of which you inquire is a self-tapping, flanged hex head screw of 10-24 thread size and 3/8" length. It is zinc plated and has a "notched style" pointed end.
    • Eugene B.
      • May 31, 1988
      • 710
      Thanks, Joe. *NM*
