C1 Help - Slung Balancer - NCRS Discussion Boards
  • Tom Wander
    '60 270 2x4
    I had the unfortunate experience of slinging the balancer. Fortunately it was at low RPM which limited the damage. Does anyone have any tricks/tips to create a tighter press fit when installing a balancer. I would prefer not to remove the engine and drill the crank snout.
    Thanks in advance
  • William C.
    • May 31, 1975
    • 6037
    Re: C1 Help - Slung Balancer
    You could try some loctite
    Bill Clupper #618
    • Mike M.
      • May 31, 1974
      • 8385
      if your harmonic balancer is the original type(steps to the rear--see prvious posts in this regard) then i wouldn't risk damaging a valuable piece of equipment. drill and tap and fasten it with a bolt like its younger brothers (63 solid lifter engines etc) mike
        Loctite "Bearing Mount" is very effective for this light press-fit type of joint, but it'll be hell getting it off next time.
