C2 Aluminum Valve Covers - NCRS Discussion Boards
  • Sheldon S.
    • March 1, 1999
    • 477
    I was wondeering how to identify the correct valve covers for a 65 coupe with the 350 HP motor. I have read some stuff about the earlier ones with different heights of the letters and of course the ones with the seam through the O in corvette but what should i look for on the 65's?
    Thanks in advance Sheldon
  • Ed Jennings
    Re: C2 Aluminum Valve Covers
    The different heights of letters and numbers of fins pertain to earlier (56-58) covers. The later covers with the bolt holes directly opposing should not have the casting flaw through the "o" except in '67 or possibly very late '66. Your 65 should have covers without the casting flaw.
    • Tracy C.
      • July 31, 2003
      • 2739
      Sheldon,
      Here is a pic of the animals your after. Note straight accross bolt holes and no casting flaw across the "o"
      tc
      • Mike M.
        Director Region V
        • August 31, 1994
        • 1463
        Great picture. What did you use? *NM*
        • Tracy C.
          • July 31, 2003
          • 2739
          simple green and hot water rinse *NM*
          • Tom D.
            • September 30, 1981
            • 2135
            villagephotos.com *NM*
            https://MichiganNCRS.org
            Michigan Chapter
            Tom Dingman
