66 327/300 Oil Pan - NCRS Discussion Boards
66 327/300 Oil Pan
  • Mark J.
    • March 1, 1996
    • 254
    66 327/300 Oil Pan
    I just turned my motor upside down and found a salvage yard yellow marker note on the bottom of the oil pan. This suggests it has been replaced. What should I look for to determine if this is a correct 66 327/300 pan?
    Mark R. Johnson
  • Mark J.
    • March 1, 1996
    • 254
    Salvage Yard Yellow Marker
    I found the answer in the JG. A correct oil pan has three 1-1/2" ribs on the left, two on the right, and drains to the rear. Mine matches, albiet, I always wonder about the history of salvage yard markings on an engine part...
    Mark
    • Tracy C.
      • July 31, 2003
      • 2739
      Don't sweat the salvage history..Some of NCRS's
      finest have salvage parts here and there. It's the repop stuff that will getcha..
      tc
        • 43232
        Re: Salvage Yard Yellow Marker
        Mark-----
        Virtually all 1963-74 Corvette small block oil pans were the same, except for 63-65 SHP engines and a few 70-72 models with ZR-1. However, the Corvette oil pan was not used for ANY other chassis. It's hard to say, for sure, if the pan is correct without seeing a picture of it.
        • Mark J.
          • March 1, 1996
          • 254
          Oil Pan Photo Link
          Joe,
          Here's a link to my photos.
          Mark
          oil pan
            • 43232
            Re: Oil Pan Photo Link
            Mark-----
            Like they say-----a picture is worth a thousand words. This is exactly the oil pan that you need. This pan is GM #3820000 and was used for most 1963-74 Corvette small block applications and was NOT used for ANY other chassis application besides Corvette. This is a "5 quart" oil pan (i.e. the capacity of the oil system at "full" with a filter change is 5 quarts).
            This pan looks to be in good shape. A good cleaning and refinishing should yield a fine appearing pan.
            • Mark J.
              • March 1, 1996
              • 254
              You made my day *NM*
                • 43232
                Re: You made my day
                Mark-----
                I should have mentioned that the drain plug is not correct for a 1966, though. You will need to change that to the 7/8" across-the-flats style plug.
