1963 Seat Track Assembly - NCRS Discussion Boards
  • Rick A.
    • July 31, 2002
    • 2147
    Folks,
    Anyone have any clue as to who I can contact about a paasenger side seat track assembly? Have a "rock" in the original one and it was one of my FAILURES at the PV when at Wildwood.
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
  • Harry Sadlock
    Re: 1963 Seat Track Assembly
    Rick, Sounds like the PV went well in all other areas, great news. Both seats on a 63 are the same. I had the same problem with my 63. The fix for mine was to remove the seat, ensure all the bolts were tight (bottom and back). I also used a level and a tape measure to ensure the height adjustment feet were at the same distance and that they sat flat on the floor.
    Harry
    38513
    • Joe R.
      • July 31, 1976
      • 4551
      Rick,
      A common problem with all mid years as the years and the weight have caused the rails in the tubes to become loose. Paragon has a service to refurbish the seat tracks however you may be able to tighten them enough to get thru PV with no problem. When you turn them over you will see a tube in a tube and the outer tube has expanded. Reducing the size back to original with a clamp or bench vise may help your problem. Don't overtighten as the seat won't slide and that would be another problem.
      Go carefully and the results will be amazing.
      JR
      • Rick A.
        • July 31, 2002
        • 2147
        Re: 1963 Seat Track Assembly - Harry/JR - THNX! *NM*
        Rick Aleshire
