67 clock resto - NCRS Discussion Boards
67 clock resto
  • Justin N.
    • February 1, 2004
    • 318
    67 clock resto
    Dear Members,
    Does the set knob on my clock screw onto(threaded) the pin through the lens? I need to removed it to rebuild clock and can't figure out how release knob. Thank you Much!
    Justin #41362
  • Joe R.
    • July 31, 1976
    • 4551
    Re: 67 clock resto
    Justin,
    Hold the shaft with a pair of side cutters (wire cutters) and turn the knob counterclockwise. It will unscrew and you'll be on your way to restoring the clock.
    JR
    • Harry Sadlock
      Re: 67 clock resto
      Justin, you might also try pliers well wrapped in electrical tape to avoid nicks or scratches on the shaft.
      Harry
      38513
      • Dixon Green
        Re: 67 clock resto
        Justin,
        Remove the back cover of the clock and then hold the shaft behind the face to avoid scratches.
        Dixon
