C1 Fuel Pump bolts - NCRS Discussion Boards
C1 Fuel Pump bolts
  • Gene B.
    • May 31, 1990
    • 144
    C1 Fuel Pump bolts
    Can anyone tell the correct mounting bolts for a 58 245 HP with pump # 4445?
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Re: C1 Fuel Pump bolts
    Gene, I'll jump in with a guess and say they should probably be a 9/16" hex. As far as a logo, if any, no clue. Best, Dennis
    • Chris H.
      • April 30, 1990
      • 817
      My 62, which may have incorrect fasteners had dishhead bolts with a large flange head and split lock washer.
      Markings are -B&H-
      Paragons replacements, 56-66, and stated grade 5, are exactly the same bolt as mine except the marking is
      R|S
      C
      I would think that mine are correct and most likely so is Paragons since the same bolts were used for so many years. What do you have?
      Chris
      • Gene B.
        • May 31, 1990
        • 144
        I think the ones I have are incoreect. They are the same as the intake bolts AP in a circle. Thnanks for the info that is helpful.
        Gene
        • Chris H.
          • April 30, 1990
          • 817
          Gene the markings I tried to put in the previous message got messed up in format.
          The slashes are the same on both sources. A vertical one at the top and two horizontals thru the center of the head.
          • John M.
            • January 1, 1999
            • 1553
            Gene,
            I believe that ALL that fuel pump bolts of this era are a flange head bolt with a reduced hex size (1/2" If memory serves me right). The reduced head size was a real advantage when installing the pump, as it gives more wrench room. My recollection is that they are an indented head bolt with a flange head and are cad/zinc plated. I do not recall any head marks, but I will look at some when I go out to the shop today. They are the same as any passenger car, and there are lots of them in the junkyards.
            Regards, John McGraw
            • Loren L.
              • April 30, 1976
              • 4104
              According the AIMs, this bolt is part #
              3751824 in both 1958 and 1965 and the 1970 Standard Parts Book id's this as 3/8" # 16 thread that is 1 1/8" long. When I dig out the 65's plastic bag, this gives up a 3/8" #16 1 1/8" long that uses a 5/16" head and is a grade 5(? - three dashes) with a "U" logo.
              • Dennis C.
                • January 1, 1984
                • 2409
                Re: According the AIMs, this bolt is part #
                I stand corrected on the use of the use of the reduced size hex. I, for some reason, thought it came into use a little later. However, what's left of my memory wants this to be a 7/16" hex, not 5/16... And the smaller hex DOES make the install easier, along with putting the camshaft on #1 TDC.
                • Loren L.
                  • April 30, 1976
                  • 4104
                  Dennis is correct at 7/16- proofing is such
                  a pain in the nether regions.
