63 Engine Harness - Is this a replacement? - NCRS Discussion Boards
  • Joe S.
    • July 31, 1999
    • 319
    Note the end that connects to the Alternator. It is the wrong rubber boot. Question though, was the white pin for locking it into the back of the Alternator on original 63 harnesses? My understanding is that the Alternator does not have the hole for this pin (My recently acquired Alternator does not have the hole). So why would the harness have the pin? Was this added later?
    Joe's 63 FI Convertible
  • Loren L.
    • April 30, 1976
    • 4104
    Service Replacement - the giveaway is
    the green horn wire - 1963 was black.
    • DANNY PANTUSO
      Re: Service Replacement - the giveaway is
      The green wire could it be the temp. wire with the connector not the horn which is a black wire. Danny
      • Michael H.
        • January 29, 2008
        • 7477
        Re: That's true but......
        It's the white plastic prong taped into the harness that would plug into a 64 and later alernator that gives it away. It's a 64-65 harness, the only one that was available for 63 from GM since about 1964.
        • Joe S.
          • July 31, 1999
          • 319
          Thanks guys. Then I have a dumb question. From a judging perspective, is a new replacement harness (Lectric, etc.) going to be worth anymore than the service replacement harness? If there is a good new replacement, who has the best?
          Thanks again
