Leveling a Coupe - NCRS Discussion Boards
Leveling a Coupe
  • Randy Adams
    Leveling a Coupe
    I need to install an adjustable outer spring mounting kit. The '64 coupe is 1' lower on the passenger side when measuring from points on the frame. I need advice on how to do this job and do it safely. I'm greatful for any assistance.
  • George C.
    • November 1, 2001
    • 568
    Re: Leveling a Coupe
    Randy,
    I would check all the rubber cushions, and then check the spring mount bolts to insure the nuts are threaded up eqqually on both sides. If the bolts are tightened the same, and the cushions are all there and in equal condition, I would look for a new spring.
    George
    #36908
    • Randy Adams
      George,
      Thanks, all bolts are threaded equally and cushions look good. A new spring may have to wait till winter. I was hoping the adjustables would help for now.
