67 master cylinder - NCRS Discussion Boards
67 master cylinder
  • August M. Heilig
    67 master cylinder
    We are looking for pt#5455509 J50 power brake master cylinder. Any help would be appreciated.
    Augie!
  • Donald O.
    • May 31, 1990
    • 1588
    Re: 67 master cylinder
    Augie,
    The J50 power brake M/C is the SAME M/C as the standard brakes. If you look in your AIM you will see that the same part number is called out.
    The J56 IS the one that is different, it has a larger bore.
    Don
