'66 BB FELPRO EXH MANIFOLD GASGETS - NCRS Discussion Boards
  • Rob A.
    • December 1, 1991
    • 2126
    Felpro makes a manifold gasget set#90502 that costs almost twice as much as the standard set. The material is different and is supposed to be a higher performance application. Anyone know just what it is that might these more expensive gasgets a better choice, if in fact they are?
  • William C.
    • May 31, 1975
    • 6037
    Re: '66 BB FELPRO EXH MANIFOLD GASGETS
    GM didn't need them, why would we now?
    Bill Clupper #618
    • Michael H.
      • January 29, 2008
      • 7477
      Rob,
      Gaskets on an exhaust manifold is a very bad idea for a number of reasons but probably the most important, especially on the particular car that you're working on is the fact that it's VERY easy to break off the ears of the manifold when torquing to specs. The end ears are the worst and I can almost guarentee one will crack.
      And... as Bill said, it's not correct.
      Michael
      • Tom D.
        • September 30, 1981
        • 2134
        NO EXH MANIFOLD GASGETS
        You mean no gasket at all?
        https://MichiganNCRS.org
        Michigan Chapter
        Tom Dingman
        • William C.
          • May 31, 1975
          • 6037
          Re: NO EXH MANIFOLD GASGETS
          That is correct, the manifolds are machined flat, and the head surfaces likewise so that under the compression of properly torqued bolts, no gasket is required. Also improves heat transfer out of the exhaust manifolds into the head and thus the engine coolant.
          Bill Clupper #618
