C1 1958 Oil Pan Gasket - NCRS Discussion Boards
  • Al C.
    • July 31, 1999
    • 274
    I've been searching the archives and the web to choose the proper (not necesarily "correct"!) and best gasket for the oil pan on this 1958 245hp engine. It appears that Fel-Pro makes an 1885, 34509, 34510 (all one-piece?). On-line photos show big differences in shape and location of large holes. Which is the proper fit for my engine, and best source? Thanks, ... Al '58 245hp
    • 43222
    Re: C1 1958 Oil Pan Gasket
    Al-----
    If you have an original oil pan, use the Fel-Pro OS 34509T (one piece). If you have a replacement GM #359937 oil pan, then use the OS-34510T.
    • Al C.
      • July 31, 1999
      • 274
      Joe - Is it possible to tell which pan I have before pulling it? I'd hate to leave the engine works exposed to blowing dust for more than the pull-amd-replace time. The photos on the web show NO large holes on the 34509 versus 2 large holes on the 34510 - does that seem right? If so mine must be the original (thus 34509).
      Thanks, ...Al
        Al -
        I don't know any convenient way to tell which one it is with the pan installed on an assembled engine. Once you drop it, flip it upside-down on a flat surface (no gaskets) and measure from the flat surface up to the 12 o'clock position on the front radius; if it measures 2-1/4", it's the original style that takes the "thin" (0.22") seal and #34509 gasket. If it's 2-3/8", it's the '75-up replacement style that takes the "thick" (0.41") seal and #34510 gasket.
