(Message Deleted by Poster) - NCRS Discussion Boards
  • vince malvagna
    • 15676
    Re: wheel fit.
    Adapters are Mickey Mouse! They alter offset, which can alter steering feel and/or place excess load on the wheel bearings and place additional bending loads on the studs/bolts. Buy a wheel properly engineered for the car or stick with the Rally wheels.
    The proper dimensions are 15" x 8" x -0.50" offset.
    • Wayne K.
      • December 1, 1999
      • 1030
      Re: wheel fit.
      Vince,
      Duke gives you good advice. I would just like to add that spacers are used from the factory by some mfgs. on some models ( such as certain Porsche models ) but the program is designed to work that way. By adding a spacer of a 1/2 to 3/4 inch you are extending the forces beyond what the mfg. designed the hub system. I remember hearing of people who lost a wheel while driving the car because of this. Very dangerous.
      • vince malvagna
        Re: wheel fit.
        I am taking your advise, Im'm going to stick with the rally wheels, Thanks for all your thoughts and advise, It's not worth the risk, Thanks Again VINCE.
