High Strength Bolts - Headmarks - NCRS Discussion Boards
  • Joe C.
    • August 31, 1999
    • 4598
    Here is what I found when I removed all 10 main bearing cap bolts from my L76 engine.
    3 bolts: "N" inside single circle.
    2 bolts: "TR" inside single circle
    3 bolts: "TR" within 4 radial lines set at 0, 90, 180, 270 degrees
    3 bolts: "M" with 4 radial lines set at 0, 90, 180, 270 degrees.
    1 bolt: "TR" with 4 radial lines set at 0, 90, 180, 270 degrees.
    I have bought 5 new bolts from GM, which are marked with "O" with 4 radial lines set at 0,90, 180, 270 degrees.
    I have bought 5 new "stud/bolt fasteners", which are marked as pictured. These are to install a missing windage tray.
    I have looked at numerous SAE, and ASTM publications, but cannot find any correlation to neither a single circle nor a "4 lines" headmark. I assume that these fasteners are at least Grade 8. Does anyone have any further info.
    I understand that common grade 5 bolts have 3 radial lines @ 0, 120, 240*
    Grade 8 have marks @ 0, 60, 120, 180, 240, 300*.
    Thanks in advance.
    Joe
  • Joe C.
    • August 31, 1999
    • 4598
    SUFFIX
    Make that 1 bolt: "M" ..........
      • 15676
      Re: High Strength Bolts - Headmarks
      SAE grades are number of radial lines plus two, so they are grade 6. Grades 3, 5, and 8 are the common commmercially available replacements.
      Not sure what the circle means, but given the size of these bolts and the torque spec, grade six is perfectly adequate.
