Attempting to wrap up this task today, previous carpet install was a mess.
Should the shift boot frame capture the edge of the carpet?
Should the carpet roll up over the horizontal surface of the transmission tunnel for say an inch all along the length of the tunnel?
Is it correct to assume that the accelerator pedal bolts on top of the vinyl pad without the use of a spacer (as shown in some catalogs)?
Thanks for any advice.
Best regards,
Charlie
Best regards,
Charlie
