Just tried to install a new tach cable (65 coupe with 327 and powerglide). Purchased a replacement from one of the corvette parts stores. I used the longer bolts to support the dash and slide it out. There appeared to be restraint from the speedometer cable and oil pressure line. I had barely enough room to attach the tach cable without disconnecting anything. The replacement cable was shorter than the old cable, but I figured there would be enough length for installation. I was wrong. Do all the replacement cables come in a shorter length? I thought about ordering one of the 90 degree adapters to see if that would solve the problem. I was going to remove the speedometer cable and clean out, but couldn't get it off at the transmission (I've got fairly large hands). Any advice related to the tach cable and suggestions for a simple method to disconnect the speedometer cable would be appreciated.
