C2 Flywheel/Crank bolt variances... - NCRS Discussion Boards
  • Tracy C.
    • July 31, 2003
    • 2739
    I'm disassembling a 66 327 passenger car engine that has an automatic trans flywheel. Do the bolts attaching the flywheel have universal application to all small block Chevy applications or are they shorter and/or an inferior grade to SHP manual trans flywheel bolts?
    thanks,
    tc
  • Craig S.
    • June 30, 1997
    • 2471
    Re: C2 Flywheel/Crank bolt variances...
    TC - torque converter flexplate bolts are shorter than flywheel bolts, I would assume the grade is the same. Personally, I use ARP bolts, they are superior and nobody will see them....Craig.
    • Tracy C.
      • July 31, 2003
      • 2739
      Thanks Craig.... *NM*
