67 rear driveshaft U-Joint problem - NCRS Discussion Boards
  • larry linkous
    My 67 vette rear U joint has started thumping against the fiberglass in the rear tunnel under a load ie gassing it just a little. What could be the problem. Thanks larry
    • 43240
    Re: 67 rear driveshaft U-Joint problem
    Larry-----
    The problem is likely caused by a fractured rear floor pan. This is a VERY common problem for mid year Corvettes. You can obtain a booklet from Paragon which describes the problem and the repair procedure. The booklet, as I recall, is very inexpensive and you NEED one.
    • Wayne P.
      • August 31, 1975
      • 1025
      The rubber biscuit in the front rear end mount has been destroyed or come out. This allows it(rear) to turn-up when torque is applied. A very common problem on C-2 and C-3 Vettes.
      • larry linkous
        Wayne I think you are correct the rear rubber bushing has broke into and is squeezed out somewhat. Thanks Larry
        • Craig S.
          • June 30, 1997
          • 2471
          When it goes completely, it leads to a loud clunk when the metal hits metal, sounds like you have a severely worn cross pin in the differential. This small bushing takes a lot of abuse, depending on how you drive....Craig
          • frank mccracken
            Joe L; Would you mind......
            giving me an "in a nutshell" explaination of what the Paragon procedure is?
              • 43240
              Re: Joe L; Would you mind......
              Frank-----
              It's been a long while since I looked at it and I can't seem to find the booklet around here. In any event, what happens on mid-years is that the rear floor cracks and "sags". This causes the driveshaft to contact the floor. The Paragon-designed repair (actually, developed by Dick Fortier, former owner of Paragon) shows how to re-align the broken panel, add reinforcement, and complete the fiberglass repair with a traditional FRP repair process.
              I've seen a LOT of mid years that suffer from this problem when I used to "hang around" a friend of mine's Corvette shop. In many cases, the problem is "sub-acute". In other words, it's present, but it hasn't developed symptoms that the owner's noticed as yet. It's progressive, so it will get worse as time goes on.
              • Craig S.
                • June 30, 1997
                • 2471
                Joe - do you know where the fracture occurs, I would like to examine my 66 and 67.....thx!.....Craig
                  • 43240
                  Craig-----
                  It's hard for me to describe beyond what I've already said. However, I would suggest getting the Paragon booklet. It's very inexpensive ($5.00) and is their #8349.
                  • Craig S.
                    • June 30, 1997
                    • 2471
                    Thx Joe, sounds like a plan and a good investment....Craig
                    • Ted K.
                      • June 30, 1991
                      • 4
                      Larry,
                      I experienced a similar problem on my 66 convertible. It turned out that some of the rivets that hold a metal reinforcement to the fiberglass floorpan had sheared. This metal reinforcement is located right behind the seats on the inside of the car and goes across from door pillar to door pillar. I slightly enlarged the rivet holes and put in stainless steel bolts in their place. The hard part was getting enough clearance under the car to slip the bolts in between the frame and undercarriage. Also, I used a floor jack and some two- by-fours to bring the floor up to proper height before replacing the rivets.
                      Ted
