1967 distributor cap. - NCRS Discussion Boards
  • August M. Heilig
    We are looking for an NCRS accepted distibutor cap. Any suggestions?
    Augie!
  • Mike M.
    • May 31, 1974
    • 8403
    Re: 1967 distributor cap.
    you'll need a Black delco dist cap. when looking down at the 9 towers, embossed in the plastic will read delco remy pat. pending. you don't want the later cap that give the patent #. sources: Junkyards, Carlisle, bloomington, dealers in driveline. junkyards usually charge a couple bucks if they don't give it to you. expect to pay 250 and up for a NOS puppy. For flight judging , a used junkyard item - with its contacts cleaned of debris of oxidation, will work just fine. for the P.V., put on an aftermarket good quality cap(accell, sorenson etc). mike
