Block Drain Plugs. - NCRS Discussion Boards
Block Drain Plugs.
  • Bob Simard
    Block Drain Plugs.
    The block drain plugs on my engine came out easily and cleanly. What is the best way to reinstall them so that they are easily removable next time? Pipe dope? Teflon tape? Anti-seize? Thanks. (This engine will never be judged.)
  • Roy B.
    • February 1, 1975
    • 7044
    Re: Block Drain Plugs.
    Replace them with brass plugs! When you paint the engine who will know? just you and ME!
    • Joe C.
      • August 31, 1999
      • 4598
      I like to use "GM Thread Sealant With Teflon". It is quite expensive, and someone will surely respond with a "generic" compound that is cheaper and just as effective.
        • 15695
        Whether you go with brass or steel plain old plumbers pipe dope will work fine.
        • Dick W.
          • 10483
          Loctite Pipe Sealant with Teflon. Can find it at most auto parts stores. Wonderful sealant, plus lubricates the threads so as you can remove the plug later without using a 3' cheater pipe.
          Dick Whittington
          • Mike M.
            • May 31, 1974
            • 8396
            for the thgreaded drain plugs on the sides of the v-8's, i'd use the teflon loctite Didkie refers to. For the press-fit freeze(soft) plugs on the block, i use 3-M weatherstrip cement to make sure they don't leak. never had one leak yet with 3-M. mike
            • Chuck R.
              • April 30, 1999
              • 1434
              I use Permatex form a gasket on freeze plugs and Permatex teflon pipe dope on threaded plugs. Both available at any fine automotive or hardware store.
              Chuck
