Two C2 Starter Questions - NCRS Discussion Boards
  • Eugene B.
    • May 31, 1988
    • 710
    Members,
    I have two questions regarding the starter on my '65.
    1) Is the starter heat shield P/N 3851295 still available from GM?
    2) Is the aluminum nose-piece (that enters the flywheel housing) painted semi-gloss black as part of the starter or is it left natural finish aluminum? The JG doesn't specify.
    Thanks for taking time to answer.
    Gene
    • 43221
    Re: Two C2 Starter Questions
    Gene----
    1) The heat shield is long-since discontinued, but available in reproduction.
    2) The aluminum nose used for 63-68 small block starters is natural aluminum.
    • Eugene B.
      • May 31, 1988
      • 710
      Re: Thank you, Joe. *NM*
