Rear Axle Oil - NCRS Discussion Boards
Rear Axle Oil
  • Ron Schaller
    Rear Axle Oil
    Fellow members: My 1989 calls for 80W-90 GL-5 rear axle oil. I tried to obtain some from my local GM dealer. They only use/sell GL-4 and that it is ok. Despite what I am being told, I am hesitant to stray from the recommended fluid. I therefore plan to go for a non-GM product that meets GL-5 specs. Any comments?
    Thanks for your help.
    • 15674
    Re: Rear Axle Oil
    GL-4 is not suitable for axles - manual transmissions only. Axles need GL-5. You can purchase any 80W-90 GL-5 at an auto parts store. If you are changing the oil add one 4-oz. bottle of of GM of Positraction additive.
    The dealer really does have GL-5 axle oil, but it's just called axle oil and the product information may not include the GL-5 identifier.
      • 43221
      Re: Rear Axle Oil
      Ron-----
      Ask your dealer for some GM #1052271 (if he still has any) or GM #89021671 gear lubricant. Either of these are the EXACT lubricant which GM recommends for your application regardless of what else it may say on the actual container.
      • Lenn #40977
        Re: Rear Axle Oil
        Joe,does this apply to C-1s as well?
          • 43221
          Re: Rear Axle Oil
          Lenn-----
          C1, C2, C3, or C4.
