1967 front shock label codes - NCRS Discussion Boards
  • Michael C.
    • January 1, 2000
    • 39
    I have two different answers from two different authorities. The car, a 67 conv 427/390hp, standard suspension. Which front shock lael is correct. EL or EK ?? Need to settle this with the correct answer. Thank You Mike Chase
    Re: 1967 front shock label codes
    "EK", P/N 3186906; there was no "EL" front shock (F41 shocks were "EN", P/N 3171488).
    • Gary B.
      • February 1, 1997
      • 7034
      John, Mike,
      There is some disagreement here depending on who you talk to. I believe that Paragon sells the EK labels for front, mid-year standard shocks. However, another source for these labels is Ray Williams (I think he calls his company "Corvette Fanatics" or just "Fanatics"). I think I'm recalling correcctly that Ray's labels were described to me by Terry MacManmon as "spot on" or something equivalent. The labels that Ray sells for the front, standard mid-year shocks are EL labels. So clearly, these two sources have a difference of opinion about which letters are correct for the front.
      Gary
        Gary -
        I just took my response info from the '67 JG, as that's the standard against which the car will be judged (unless it gets changed prior to that time).
        • Gary B.
          • February 1, 1997
          • 7034
          John,
          My post in response to Mike's question was to simply to confirm that there is a difference of opinion as to the letters. I don't whether the EL is correct or EK or both or neither. I wish some of the Bowtie judges would help us out here.
          Gary
