Fuel / PCV line clamps & Starter Field Coil screws - NCRS Discussion Boards
  • Zachary K.
    • March 1, 1986
    • 162
    What year did the fuel line hose and PCV hose spring clamps change from square ends to the rounded ends?
    Also wondering what year the starter field coil mounting screws changed from sloted screws to phillips screws?
    I know these are only slight deductions on the judging field but it's an easy fix for everyone to make on their cars. Thanks.
    1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
    1969 L71 LeMans Blue, Bright Blue Convertible
    1970 L46 Monza Red, Light Saddle Convertible - Duntov
    1976 L82 Classic White, Firethorn
    2013 LS7 Black, Ebony, Convertible
    Moved on -
    2006 LS2 Black, Ebony, Convertible
    • 43221
    Re: Fuel / PCV line clamps & Starter Field Coil sc
    Zachary-----
    The phillips head starter field coil screws were phased in over the 1967 to 1969 period. Starters with the first 4 digit part numbers of "1107" were originally fitted with slotted head screws. Starters with "1108" or "1109" were originally fitted with phillips head screws. With virtually no exception, 1967 and earlier starters used the slotted head screws. 1968 was a transition year. With only minor exception, 1969 and later used the phillips head screws.
    Of course, after any starter goes through a high production, commercial rebuilder's operation these could change. Rebuilders strip down cores to component parts, save as many parts as they can (including these screws), and replace only what absolutely has to be replaced (i.e. brushes, bearings). All of the salvaged parts go into bins to be drawn from as the starters are "built up", much in the same fashion as the starters were originally assembled new in Anderson, IN. The difference is that all of the parts are USED and may come from any number of different "generations" of starters. Where parts are interchangeable, they go into the same bins.
    As far as the fuel line clips go, I have no information.
    • Zachary K.
      • March 1, 1986
      • 162
      Thanks Joe, your a great help as always!
      Moved on -
