62 Motor mount - NCRS Discussion Boards
62 Motor mount
  • Terry D.
    • May 31, 1987
    • 2692
    62 Motor mount
    Thought I would try something new, at least for me, and mount the engine frame mounts to the engine instead of leaving them on the frame. After snugging down the bolts the frame mounts are loose between the rubbers, is this right? It's as though the spacer is too long. Didn't notice this when I took it apart. I have the correct rubber pieces but not sure about the bolts or spacers.
  • Mike M.
    • May 31, 1974
    • 8389
    Re: 62 Motor mount
    Sounds like the sleeves(spacer) is the problem. don't think manner of frame mount to frame would make any difference. there should be no slop between motor mount/rubber cushions/frame mount. Mr Gravity disallows such. good luck, mike
