more electrical issues-C22 - NCRS Discussion Boards
  • john pickens
    C2 roadster 1965 327/350. Shorted power antenna-up but no down and no power to that portion of the switch at the under dash harness. AIM shows body connector
    with a 14 gauge black wire for the down portion of the switch. Where exactly is the body connector and how accessible is it? Thanks in advance.
  • Donald O.
    • May 31, 1990
    • 1588
    Re: more electrical issues-C22
    John,
    The body connector is usually just above the drivers left knee, on the body. It is normally readily accessible.
    I think that the up wire is 14 gauge and is color coded "Black with White stripe". The other wire is 14 gauge and is color coded "Black".
    Sounds like you need a full color wiring diagram.
    Don
