CAM -2 Fuel - NCRS Discussion Boards
CAM -2 Fuel
  • Rick A.
    • July 31, 2002
    • 2147
    CAM -2 Fuel
    Folks,
    Getting close to getting my 1963 Z06 back! I have been advised to run a mixture of UNLEADED and CAM-2. What kind of mixture would folks recommend? Something along the lines of 3 or 4 to 1?
    Also, for anyone in the Baltimore, MD area - where can I buy CAM-2?
    Rick Aleshire
    2016 Ebony C7R Z06 "ROSA"
    • 15672
    Re: CAM -2 Fuel
    It depends on what the actual CR is and what cam you installed. Did you measure the dimensions you need to compute CR like deck clearance and head gasket compressed thickness? The LT-1 cam will handle more compression than the Duntov cam.
    Many run SHP/FI engines on pump premium with just slight timing adjustment. If the CR is high you may need to blend in some high octane race gas or 100LL avgas, but I doubt if more than 25 percent would be necessary in any case.
    • David W.
      • December 1, 1999
      • 272
      Re: CAM -2 Fuel
      Cam-2 octane level is 110 so you can use a mix ratio that will get you to the octane level you desire. It's distributed here in Ohio at 'Speedway' gas stations, owned by Marathon oil. The pump is off to the side of the station and has a very short hose so that you cannot pump it directly into a car. It has to go into a gasoline container, due to legal reasons of selling leaded gasoline. I use it occasionally (diluted) and it is a very noticeable difference in performance. Using it straight would probably require wings. It's still around $4 per gallon and doesn't seem to move as much as 'regular' fuel.
      • Joe Pearson
        Re: CAM -2 Fuel
        Rick, I buy Cam2 online and have it delivered in 5 gal containers by UPS. I use one 5 gal per tankful the rest unleaded premium and a bottle of Lead Supreme 130. I have a 66' with factory 427/425 with about 11:1 CR and it runs well. Let me know if you want online sites to purchase the CAM2 & Lead additive.
        • Rick A.
          • July 31, 2002
          • 2147
          Re: CAM -2 Fuel
          Joe,
          would love to know the online sites! you can drop me an email if you don't want to post:
          email: c5vetter@cablespeed.com
          FYI - 1963 Z06 (L84 fuellie) coming out of restoration
          Rick Aleshire
          • Mike M.
            • May 31, 1974
            • 8383
            Re: CAM -2 Fuel
            rick: you can buy it at 75-80 dragstrip which i presume you know the location of--if not , let me know.mike
            • Rick A.
              • July 31, 2002
              • 2147
              Re: CAM -2 Fuel - thnx Mike *NM*
              Rick Aleshire
              • Patrick T.
                • September 30, 1999
                • 1286
                Re: CAM -2 Fuel
                There is a gas station on the corner of Rt.27 and Rt.108 called Tucker's Gas and Go in Damascus, Maryland that sells Cam 2 racing fuel, 110 octane at $3.50 a gallon. All the racers stop there on the way up to 75-80 Dragway. Went by there today. PT
                • Rick A.
                  • July 31, 2002
                  • 2147
                  Re: CAM -2 Fuel - THNX!!!!!! *NM*
                  Rick Aleshire
                  • Craig S.
                    • June 30, 1997
                    • 2471
                    Re: CAM -2 Fuel - $3.50 per gallon
                    Heck, that price is not bad, unleaded premium just hit $2.33 per gallon at Circle K (Union 76) yesterday in Tucson. We had a basic 18 cent hike in all of our prices in the past 2-3 days...... Craig
                    • David Van Weele
                      Re: CAM -2 Fuel
                      Rick, I just got back from 4 days in Baltimore. I attended a seminar on Land Development.
                      I use 93 Octane unleaded and then add a some of the lead supplement that Jack Podell sells, I have been using this since he started selling it.
                      Did you rebuild your engine with the two sets of head gaskets like Chevy did to lower the CR?
                      Dave Van Weele
                      • Zachary K.
                        • March 1, 1986
                        • 162
                        Re: CAM -2 Fuel
                        Just paid $5.60 a gallon for it here in New Jersey.
                        1967 L79 Sunfire Yellow Black Leather Convertible- Duntov
                        1969 L71 LeMans Blue, Bright Blue Convertible
                        1970 L46 Monza Red, Light Saddle Convertible - Duntov
                        1976 L82 Classic White, Firethorn
                        2013 LS7 Black, Ebony, Convertible
                        Moved on -
                        2006 LS2 Black, Ebony, Convertible
