Delco Coil Part Number ID help - NCRS Discussion Boards
  • David W.
    • December 1, 1999
    • 272
    I'm having no luck identifying a coil that came with a bunch of '66 Corvette parts. It has Delco-Remy on the bakelite top and the embossed partial part number of 298 on the side with B-R below that. Also is there any way to test a coil other than install it? Thanks, David
  • Dave S.
    • August 31, 1992
    • 2925
    Re: Delco Coil Part Number ID help
    David,
    I can't help with the part number but the only way to properly test an ignition coil is to put it on a car an run it until full operating temperature is reached and the car is driven some distance. Continuity tests are a good start but are not 100%.
    • David W.
      • December 1, 1999
      • 272
      Still Need Part Number ID help
      Thanks for the info David. I just googled the number and the only listing I could find was for a 69 Z28. I still think it must have a Corvette application as it was with Corvette only parts. Any additional help would be appreciated.
      • Dave S.
        • August 31, 1992
        • 2925
        Re: Still Need Part Number ID help
        David,
        I'm sure it is not a Corvette coil. The camaro application seems right, but others can confirm that.
        • David W.
          • December 1, 1999
          • 272
          I'm tending to agree with you. Looks like a future eBay item...
