69 trans lube - NCRS Discussion Boards
69 trans lube
  • KELLY THEAKER
    69 trans lube
    went to install speedo gear and lost it in the m21 cavity , any way after retreiving , i installed with the cable, is this going to stay on or is there a clip i am not aware of ? then i filled the m21 case with castrol synthetic 75w90gear oil API GL5, ok product for this application?
    • 15672
    Re: 69 trans lube
    The spec is Mil-L-2105D and 80W-90 GL-5 is the commercial equivalent. Some report leaks using synthetic, so I would recommend a mineral oil based product or the GM axle oil.
    • Dick W.
      • 10483
      Re: 69 trans lube
      Synthetic is a very superior lube, but unfortunately it will invent places to leak. It is next to impossible to seal an older engine or transmission so it will not leak with synthetic.
      Dick Whittington
