The Quadrajet I took off my engine has a number 7035530, which doesn't match the TIM&JG for my 68 L79. Anyone know what application my carb was for?
Quadrajet question
Re: Quadrajet question
Dave------
I can't tell you the original application of the carburetor but I can tell you that whatever the original application was, it was NOT originally used on any Chevrolet model car. My guess would be that it was originally used for some Cadillac application. Very likely, this carb is a previously re-manufactured unit as produced by commercial rebuilders. With commercial rebuilders, the cores are stripped down and then built up into carburetors for any number of applications which may differ from that originally stamped on the carb.
For components like carburetors, rebuilders have much less "flexibility" as to what a carburetor core can ultimately be used for than they do with components like starters and alternators. However, they are still able to reconfigure and "mix-and-match" components in a great number of ways. For rebuilt carburetors the only thing that matters is the number assigned to the unit by the rebuilder. Usually, this is on a paper tag attached to the carburetor and/or on the box that the carb is supplied in. Neither of these methods of identification usually lasts very long after the carb is installed.In Appreciation of John Hinckley- Top
Dave------
That's different. GM #7028212 is a Q-Jet used pretty much across the board for 1968 Chevrolets except Corvette. It's configuration is very similar to the Corvette Q-Jet except for internal calibration. Once again, I'm pretty sure that it likely got on your car as a commercially rebuilt carb. Commercial rebuilders could easily reconfigure this carb to the Corvette spec and the '212' core is VERY common.In Appreciation of John Hinckley- Top
