64 Front Hub Bolts - NCRS Discussion Boards
64 Front Hub Bolts
  • Neil L.
    • February 1, 1997
    • 44
    64 Front Hub Bolts
    Are the front hub bolts for a 64 still available from GM, and if so what is the part number?
    • 43221
    Re: 64 Front Hub Bolts
    Neil-----
    The front hub wheel lug bolts originally used for 1964 Corvettes, GM #3775683, were discontinued from SERVICE more than 35 years ago. These bolts were 1-11/16" in overall length. A series of supercessive part numbers were used over the years culminating in the current SERVICE bolt, GM #3910340, which is 2" in overall length but will SERVICE your application perfectly. The GM #3910340 has been the only available part from GM for the last 20 years for your application.
    Reproductions of the original bolts, which may or may not be 100% correct, are available in the Corvette aftermarket.
