Rear Wheel Bearings - Timken Numbers - NCRS Discussion Boards
  • Mike Cobine
    I was checking on rear wheel bearings for my '79 and found that only the GM numbers are listed in the archives. Does anyone have the Timken numbers?
    Inner Outer
    Bearing 9417784 457052 GM Bearing
    Seal 3794002 14079472 GM Seal
    9178S 5113 National Seal
    Thanks.
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Rear Wheel Bearings - Timken Numbers
    the 9417784 is also a pinion bearing for a "F" body
    • Wayne M.
      • March 1, 1980
      • 6414
      Here's what I carry in my "road kit", good for one side [Timken orange and black boxes]
      -- Inner race (S-9/9417784 equiv.) M86649; Inner cage/rollers M86610
      -- Outer race (S-8/457052 equiv.) M86610; Inner cage/rollers M86649
      There are other numbers on the Timken boxes, but do not also appear on the bearing edges.
      These same numbers appear on an NDH bearing set I have
      • Mike Cobine
        Thanks, Wayne
        This will let me check on prices at the local bearing houses.
        • Mike Cobine
          oops - something wrong
          The number on the inner race is the same as the cage and rollers below.
          Likewise, the outer race is the same as the cage and rollers above.
          • Wayne M.
            • March 1, 1980
            • 6414
            Must'a mixed the boxes/contents.. try this
            Found 2 UNOPENED sets with GM part numbers (from box ends) from the '60s.
            Outer; (GM # 7450700) S8 LM48548 / LM48510
            Inner: (GM # 7451202) S9 M86649A / M86610
            Hope that works.
            • Mike Cobine
              Great, thanks! . *NM*
