Recommendation for non-petroleum lubricant - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 7024
    Can someone give me some recommendations for a non-petroleum based luibricant? It seems like
    every container of every lubricant I own says "contains petroleum distilates", which I assume means it should not be used to lubriate rubber items. The bushing I want to lubricate to faciliate installation says to use a non-petroleum based lubricate, which promted this question.
    Thanks in advance,
    Gary
  • Dick W.
    • 10483
    Re: Recommendation for non-petroleum lubricant
    Would possibly graphite work?
    Dick Whittington
    • Michael W.
      • April 1, 1997
      • 4290
      KY jelly?
        • 43222
        Gary----
        Silicone is a non-petroleum-based lubricant. The spray forms of it may use a petroleum-based product as a carrier solvent, but I think that the grease forms, available in tubes, do not. Also, there are specific lubricants on the market for brake part use. These contain no petroleum products.
        • Christopher R.
          • March 31, 1975
          • 1599
          soap
          • Rob A.
            • December 1, 1991
            • 2126
            KEL brand "PURE SILICONE" spray, stock#57555(110B) 800 334 2130
            • Gary B.
              • February 1, 1997
              • 7024
              Thanks everyone *NM*
              • Terry F.
                • September 30, 1992
                • 2061
                You know what KY stands for? Terry:_)
                • Terry F.
                  • 2061
                  Peanut Butter? :_)
                  • Doug Flaten
                    I've used a tube called Syl-glide (sp) for years. It is a silicone lubricant.
                    • Floyd #21606
                      Doug, where do you get Syl-glide silicone lubricant and is it high temp?
                      Floyd
                      65 Fuelie
                      • Doug Flaten
                        I don't recall where I got the tube since it has been several years. However, at that time, I think we had Car Quest and Checker auto parts that I did most of my business with at the time. A quick search and I found a site that says Napa carries it. Sil-Glyde's website is below says it is good from -20 to 500 deg.
                        I used SIL-GLIDE made by the American Grease
                        Stick Company, Muskegon, Michigan 49443
