1958 oil pan - NCRS Discussion Boards
1958 oil pan
  • Justin B.
    • March 1, 1996
    • 478
    1958 oil pan
    Can anyone tell me if the 58' high performance (290 h.p.) oil pan has the flapper door in it?
    • 43234
    Re: 1958 oil pan
    Justin------
    Yes, I believe that it did.
    • Loren L.
      • April 30, 1976
      • 4104
      I don't think so - I believe the first
      "trapdoor" appeared in the 60-1 HP engines - 58 was just a regular 3 step pan.
      • Dennis C.
        NCRS Past Judging Chairman
        • January 1, 1984
        • 2409
        Tend to agree w/Loren...
        At least my 58 290 HP had no swinging oil door.
          • 43234
          Re: Tend to agree w/Loren...
          Dennis, Loren and Justin-----
          I could very well be in error here. I thought that the GM #3736615 oil pan used for all 1958 Corvettes had the "trap door" baffle. However, the latter feature may not have come along until the GM #3769761, which was first used for 1960 with mechanical lifters.
          I think that this may summarize the situation with these C1 oil pans:
          GM #3736115---used for all 1957-61 Corvettes EXCEPT 60-61 with SHP---no trap door
          GM #3769761---used for 1960-61 with SHP---has trap door
          GM #3789629----used for all 1962 and all 1957-61 SERVICE---has trap door
          GM #359937----SERVICE replacement for 3789629; has trap door and uses the 75+ style 0.41" thick front oil pan gasket instead of the 0.22" thick used for all of the above pans
          I believe that all of the above oil pans are externally virtually identical except for spot welds and, possibly, other minor nuances.
